Displays Flow Monitor collector information.
collector | Specifies to send flow information to a collector. |
collector_name | Specifies the name of the created collector. Range is 32 characters. |
all | Specifies to show Flow Monitor information for all collectors. |
detail | Specifies to show all information associated with the specified collector. |
N/A.
If detail is entered, the source and destination IPv4 addresses, source and destination UDP ports, VR name, and export MTU size are displayed.
If collector_name is not entered, then a list of collectors is displayed.
The following command displays detail information for a collector with the name 'c1':
# show flowmon collector c1 detail Name : c1 Destination IP address : 11.1.1.100 Virtual Router : VR-Default (default) Source IP address : 11.1.1.1 Source UDP port : 46562 (default) Destination UDP port : 4739 (default) Export MTU : 512 (default) Refresh time : 600 (default) * (pacman debug) 5420F-24T-4XE-SwitchEngine.13 # * (pacman debug) 5420F-24T-4XE-SwitchEngine.13 # show flowmon key k1 detail Name : k1 Type : IPv4 Group : g1 Destination IP address : 11.1.1.101
This command was first available in ExtremeXOS 32.2.
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
